0.52.1 - Fixed: after an update the device rolled back to the old version
0.52.0 went out in the evening. Within the hour: "does not start."
That is a bad report on a KVM, because the box is often the only way to reach the machine it is plugged into. There are two firmware slots for exactly this reason, and the fallback did work - the board was up on the previous version. From where the operator stood, the new one simply refused to start.
The image was fine
I flashed the released image over the cable and watched it boot. Then six more times, five of those with the slot marked the way an update leaves it. Full boot every time.
So the image starts. Something else rolled it back.
The device knew
Serial on this board is the chip's own USB, and a restart makes the port disappear - which is why nobody had ever captured the log of a failing boot.
The device keeps its own log, and that one survives a reboot. Every boot writes what ended the run before it:
--- boot: v.0.52.0 ---
boot: after another watchdog (rst 0x10); running ota_1 (confirmed)
A watchdog, not a crash. The boot after the update hung before it could print a line, the watchdog reset the board, and the bootloader read that second reset as "the new image does not run".
Three updates, three rollbacks, the same line every time. It needs a picture coming in, which is why it had looked random for weeks.
What was actually wrong
The capture receiver writes every frame straight into memory, and at 1080p30 it is busy nearly all the time.
An update ends with a software restart, and that is not a power cycle. The system stops what it can on the way out, and for this transfer it simply aborts it - but one already running on the bus cannot be stopped in the middle. So the restart can cut a write in half, and what that leaves behind is enough to stop the next boot dead.
The fix is to stop the receiver properly first: close the input, let the transfer end between frames instead of inside one, then reboot. It hangs off the restart itself, so every deliberate reboot in the firmware gets it.
Before: three updates, three rollbacks. After: eighteen in a row, not one of them undone.
It also explains the two rollbacks I could never account for, in August and last week. Both were written off as intermittent. They only looked that way because they needed a signal on the input.
