The demo is a whole fake computer now
There is a demo of ESP-KVM at demo.espkvm.io. No hardware, no sign-up, no install. One page, about 300 KB, and you are looking at the console.
What is real and what is not: the console is the real one, the same code the firmware serves, built from the same repository. The device underneath it is faked. The page intercepts the calls the console makes and answers them itself, out of data captured off a live board.
Behind those answers is a machine, not a video of one: a state machine with stages, a clock, and an 80x25 character screen with the same geometry the firmware reports for a real UEFI console.
The page opens on a machine mid-POST and lands on "No boot device found". The screen tells you to pick an image under Media. Choosing one writes the same setting that mounts a disc on a real device. Reset boots it. The prompt takes the keys you type. Do nothing for fifteen seconds and the demo picks an image itself, and the first thing you do stops that for good.
There are four things to boot, and each falls over in its own dialect:
- HalfOS Life - a shell. Type
startxand the pointer constellation comes up. Type something unwise at the prompt and you get a kernel panic with a call trace. - Sheeps XP - flat hills, walking sheep and a taskbar, which is the picture above. The flock gathers round the pointer once you have taken control, and grazes when you leave it alone. Click the black sheep and the machine stops with
BLACK_SHEEP_NOT_RESPONDING, wool.sys, "contact your shepherd". - Pear OS - a smiling computer, then a progress bar that sticks at nine tenths, then a desktop with a dock. One tile in that dock tells you to restart your pear.
- memtest - a memory test that never finishes, with a pass counter climbing until it finds a one-bit failure.
Every crash screen is text on purpose. Select and Copy light up on them and really work, because there are characters there to read.
The firmware update runs end to end too. The demo serves its own manifest, offers a newer version, streams an image of the right size in chunks so both progress bars move, then fails every call for seven seconds while the "device" restarts, and comes back on the new version.
Building this found two bugs in code that ships. A refused image left the console stuck behind its own full-screen overlay, with only a reload out. And the console read every keyboard report as a fresh press, so two overlapping keys repeated a letter, which is what fast typing looks like.
