0.14.0 - WireGuard, and an API simple enough for a script
vpnapinetwork
WireGuard. The device can join a WireGuard peer over its existing network connection, off by default. It is a split tunnel: only the device's own tunnel address goes through WireGuard, so the console stays reachable on the local network at the same time. The device generates its own key the first time and shows you the public half to paste into your peer; you give it the peer key, the endpoint and a tunnel address. Bring-up runs on its own task, so a peer that is slow or unreachable never holds up boot or the web server.
An API a script can use. The console drives the target over a binary WebSocket protocol, which is efficient and awful to write against. There are plain HTTP endpoints for the same things now: fetch one JPEG of the screen, move the pointer, click, press a key, type a string. Enough for a monitoring script, or for an agent that has to look at a machine and press something.
Because those endpoints hand out the same control the console has, they are behind a setting that is off by default, and each call still needs a session and a target attached.
Release v.0.14.0 on GitHub
