0.15.0 - bring your own certificate
security
Since 0.11.0 the device has been its own certificate authority. That works if you are willing to import it once per machine. If you already run a CA, or the device has a real name and a real public certificate, importing anything is the wrong answer.
So install your own. Upload one PEM blob, the chain first and then the private key, which is what cat fullchain.pem privkey.pem gives you. The console is served with it. Delete it and the device goes back to the identity it makes for itself.
Two things make it safe to try on a device you cannot walk to. The pair is checked before it is stored: that it parses, and that the key belongs to the certificate. And if the TLS stack still refuses it at start-up, the server falls back to the self-signed certificate instead of not coming up at all.
Release v.0.15.0 on GitHub
