0.16.0 - Tailscale, right on the device
WireGuard wants somewhere to connect to: a peer with a fixed address, or a port opened on your router. The device now speaks Tailscale natively instead.
Set a Tailscale auth key in Settings and the device joins your tailnet. Since 0.77.0 the key is optional: a Sign in to Tailscale button does the same. It is then reachable at its 100.x address, or its MagicDNS name, from anywhere you are signed in - NAT traversal handled for it, nothing forwarded, no gateway machine in the middle. It is built on a native client ported to ESP-IDF 6, and it runs on its own task, so joining never holds up boot.
The certificate follows: it is re-issued to name the tailnet address and the MagicDNS name, so the console is trusted over Tailscale the same way it is on the local network.
The console is installable. It ships a manifest, a service worker and icons, so a phone can add it to the home screen and run it full screen, without the browser's own bars. Touch control became a proper trackpad with acceleration at the same time.
The device's own certificate authority is now named after the device, so it is recognisable in a phone's list of trusted credentials, instead of one more identical entry.
