0.32.0 - settings to a file, and back
Two buttons at the foot of Settings: save to a file, load from a file. For the two things you actually do with settings. Keep a copy of a working setup before restoring defaults, and set a second device up like the first.
The file is plain JSON with the firmware version and the board in its header, so you can read it and know what it came from.
Two things it deliberately does not carry:
- passwords and keys, because the device never serves them at all - they cannot be in a file it writes;
- the device's own identity. Hostname and static addresses stay as they are, because two devices answering to one name means two certificates and a browser that trusts neither.
Loading a file shows what it would change before anything is written, and says afterwards what it skipped instead of a bare "done".
