0.42.1 - the keyboard that died while the machine slept
diagnosticsinputhardware
The machine went to sleep. When it woke, the keyboard and the mouse were dead.
The console has a button for exactly this - it presents the keyboard to the target again, as if the cable had been pulled and put back - and it did nothing. Nor did pressing it twice more. Nor did restarting the device, which starts by doing the same thing and then tries three more times on its own: four presentations, and the target never answered one of them. Nor did pulling the cable at the target's end, which turned out to reboot the device, because on this board the target's five volts come back down that same lead. What worked in the end was pulling every cable and giving the board a cold start.
The obvious conclusion by then was that something on this side gets stuck by a sleeping host and only a power cycle clears it. That was wrong, and one number said so. TinyUSB tracks whether there is a live bus at all, separately from whether the target has enumerated us, and that flag was false. There was no bus. Every re-plug had been toggling a pull-up on a wire with nobody at the other end: the machine suspended the bus on its way down, and its port came back from sleep with no power on it.
Nothing on this end can reach that, and the device should not have pretended otherwise. The status pill separates the two silences now: a target that has stopped listening, which re-plugging does fix, and a port with no power, which wants the cable re-seated at the machine or the machine restarted. You are offered the repair only when it can work. Both states are on the API too, in GET /api/v1/system/usbprobe, next to the enumeration trace.
Three smaller things came out of the same afternoon. The log now writes the bus going quiet and coming back, because a keyboard that dies over a lunch break used to leave nothing at all behind. A re-plug asked for by hand takes a second rather than 100 ms, since a hub is allowed to ignore a change shorter than its debounce, and a button press has no deadline to meet. And the automatic retry no longer spends its three attempts on a port that has no power - it waits, keeps them, and writes one line saying why.
Release v.0.42.1 on GitHub
