A macro that waits
inputscreen-texthome-assistantconsole
0.47.1 is about the device doing things on its own. Until now it could send a macro and read a text screen. Now it can put the two together and wait.
Runbooks
A runbook is a macro with two new lines. wait Press F2 holds until a row of the screen says so, gone Loading until it stops saying so, and timeout 120 sets how long to hold. It runs on the device, so it carries on with the browser closed, and it fails with the line it was on when a phrase never turns up. Enter the setup, pick the boot device, answer an installer: the sort of thing that used to need somebody watching.
Waits only see a text screen. On a picture they wait out their timeout and say so. Each runbook is a button in Home Assistant, with a sensor saying how the last run went.
DuckyScript
DuckyScript is Hak5's payload language for the USB Rubber Ducky. The name and the duck are theirs.
Paste a Hak5 payload into a macro or a runbook and it runs as-is: REM, STRING, DELAY, DEFAULT_DELAY, REPEAT, and chords like GUI r. It is recognised by its upper-case verbs, so there is nothing to switch. Keyboard only.
A scheduler
Five-field cron lines that fire Wake-on-LAN, an ATX button, a runbook or a restart. It needs a wall clock, so it sets one over SNTP - a server on the local network is fine, no internet needed - and does nothing, and says so, until the clock is set.
Push notifications
When a watched phrase appears, or the screen goes blank, the device sends a message to Telegram or a webhook. On the MJPEG codec the screenshot goes with it, and the tail of the device log can too, so the alert carries what explains it. Off by default, on its own low-priority task, and it borrows nothing from the encoder's internal RAM.
The script language is written up in one place: espkvm.io/scripts.
Release 0.47.1 on GitHub
