The device draws its address, link, capture status and health across a few pages. A shorter panel shows fewer lines, and the address is the line it keeps. A line that does not fit steps along a character at a time.
Good to know
- These controllers cannot tell how big the glass is, so Settings → Display picks the panel by controller and size in one list.
- In hotspot mode it shows the network and its password as a QR code, in turn with the same as text. Panels too short for a readable code show only the text.
- It can be turned upside down in the settings, for a panel mounted that way. The switch applies at once.
- It can also go on two pins of its own instead of the capture bus: name them as OLED SDA and OLED SCL.
