0.2.0 - boot the target from an image on a card
mediastorage
To fix a broken machine you need something to boot from, which until now meant walking over with a USB stick.
Put disk images on the device's microSD card, pick one in the new Media tab, and the target sees a USB drive with that image in it. It boots from that the same way it would from a stick you plugged in yourself.
Two things to know in this version:
  • the card is served read-only, because this board cannot write a microSD reliably, so you prepare images in a card reader; since 0.49.0 the card is writable and images upload from the console;
  • the card must be FAT32, and one image can be at most 4 GB, that limit is FAT32's, not ours. exFAT cards work since 0.54.0, and images over 4 GB since 0.55.0.
Reads run at 4 MHz, about 1.5 MB/s 40 MHz, about 9 MB/s, since 0.49.0. A heavy graphical image takes minutes to boot, a small rescue image about a minute. Higher clock rates fail on this chip.
Release v.0.2.0 on GitHub
