0.25.0 - the device keeps its own log
diagnosticsdisplayupdate
When a device misbehaves and reboots, the evidence goes with it. Catching it meant having a serial cable plugged in before it happened, which nobody does.
The device keeps a log now, in a small ring in memory that a restart does not clear. After a boot that failed you can come back on a working firmware and read what the failed one said. Diagnostics, then "Download the log".
It holds no passwords or keys. It does name your network, your addresses and the MAC, and the console says so where you download it. This is a file people paste into issues.
The update shows on the little screen too: the percentage while the image arrives, then verifying, then restarting, and what went wrong if something did. The console has just given up its video connection for the duration, so whoever is standing at the box has somewhere to look.
One more fix, and the second time this one bit. Adding an endpoint pushed the web server's route table past its end, and the route that fell off was the keyboard and mouse channel. Registering past the end used to fail silently; it says so in the log now.
Release v.0.25.0 on GitHub
