0.4.0 - Wake-on-LAN and a fixed address
Two small things.
Wake-on-LAN. If the target keeps standby power and has WoL switched on, the Power panel can now wake it with a magic packet. Put the target's MAC address in Settings and press Wake. No optocouplers, no wiring, nothing to solder.
Static addressing that works. The Network tab has had address fields for a while and they did nothing. They take effect now, with DHCP still the default. Two ways back if you get it wrong: an address that does not parse falls back to DHCP at boot, and the board's button reverts to DHCP as well as clearing the password. A wrong but valid address is a button hold away from fixed.
