0.50.0 - swap the card while it runs, and a picture that keeps up
storagevideoconsole
Two things in this release. One is a feature I had been putting off. The other is a bug a reader found while working in a BIOS, and it had been there since the first MJPEG stream.
The card can come and go
Until now the device looked at the microSD slot once, at boot. Take the card out and the target kept a drive that no longer answered. Put one in and nothing happened until a restart.
Now the device checks the slot every five seconds while the card is idle. The check is one sector read. Pull the card and the drive disappears from the target. Push it back and it mounts at 40 MHz and is offered to the target again.
A card the target is reading is never idle for five seconds, so that check alone would miss the worst case. So a read that fails also asks for a check. I pulled a card in the middle of a copy, and the device noticed 4.6 seconds later.
Testing it turned up three more bugs:
  • One pulled card dropped the bus from 40 MHz to 2 MHz in ten milliseconds.
  • An empty slot wrote five lines to the log every five seconds.
  • With no card in, the whole-card medium logged an error.
A pulled card now costs one speed step, and an empty slot is quiet. One limit stays: on a board that uses WiFi, the WiFi chip shares the SD controller with the card, so a card put in after boot is picked up only after a restart. Pulling a card out is noticed on every board.
The picture was one step behind
A reader wrote that working in a BIOS through the console was hard: the picture always showed the screen before the last key. Press down, see the old menu. Press down again, see the menu after the first press.
A browser shows an MJPEG stream as a row of images. It draws an image when the marker that ends it arrives. My firmware sent that marker at the start of the next image. At 30 frames a second nobody sees the delay. But on a still screen the device sends a new image only when something changes, or every five seconds. So each image waited for the next key or for five seconds to pass.
Each image now carries its own end marker. Same still screen, measured on the Function EV:
Old firmwareNew firmware
End marker of the first image5.0 s after the image45 ms after the image
H.264 never had this bug: it sends every frame, even on a still screen.
Release 0.50.0 on GitHub
