0.83.1 - Power on over USB, and a menu on the screen
A small release, mostly for boxes like the JetKVM Mini that have no wires to the PC's power button.
Power on over USB
A USB keyboard can wake a sleeping PC with a key press. ESP-KVM now sends the same wake signal. It is in the power menu, on the "No signal" screen, on the buttons on the box, in schedules and in Home Assistant. The API call is POST /api/v1/power/usb.
It always wakes a PC that is asleep. A PC that is fully off turns on only if its BIOS has an option like "Power On by USB Keyboard" and keeps the USB port powered when off. In Windows, Fast Startup has to be off for that.
A menu on the status screen
Set a button's press or hold to "menu on the screen" in Settings, Buttons. A short press then goes to the next item and a hold picks it: power on over USB, Wake-on-LAN, the ATX buttons, a screenshot, a dashcam clip, screen off, the network mode or a restart. Reset, force off, a restart and a network change ask for a second hold. The screen says whether the action worked, and why not if it did not. The menu works on every status screen ESP-KVM drives.
The JetKVM Mini
Both side buttons on the Mini can now be set up. The top one still flips the status pages and turns the screen off. The bottom one opens the menu. Held at start-up, it still resets the password.
Square screens turn
The round GC9A01 and the Mini's ST7789 now turn in quarters: Settings, Display, Turned. Upright, 90° either way or upside down, for a box that stands on its side. A screen that was set upside down stays that way.
A backup goes back from the flasher
The web flasher could already save the whole flash before the first install. Now it writes that backup back too: pick the file under "Install a file: another version or a backup". The device is then as it was when you saved it, settings included. On a JetKVM Mini that is also the way back to JetKVM's own firmware.
The full list is in the changelog.
