← All cases
ESP-KVM is free, open-source firmware that turns an ESP32-P4 board into an IP-KVM: another computer's screen, keyboard and mouse in your browser, from the BIOS up. This is a printed case for one, made by someone who built it. What it does → Try the demo →
JetKVM Mini mount / frame
A case by Flaps
A printed frame that protects the JetKVM Mini and screws to a wall, in versions for the Mini and the Mini W.
Model on Printables
Photo by the author.
Two halves close around the Mini. The bottom has two countersunk holes for wood screws, so it hangs on a wall. The back is a little wider for the cables.
  • The Mini version has a cut-out over the Ethernet port, so you can press the cable's release tab.
  • The Mini W version is drawn from a Mini. The author has no Mini W yet.
  • The halves take M2 screws: machine screws with threaded inserts, or 12 mm self-tapping screws. Assembly notes are on the model page.
Fits
