← All cases
ESP-KVM is free, open-source firmware that turns an ESP32-P4 board into an IP-KVM: another computer's screen, keyboard and mouse in your browser, from the BIOS up. This is a printed case for one, made by someone who built it. What it does → Try the demo →
Case for the M5Stack Add-on Display In
A case by Evgenij Spitsyn
A cap for the HDMI add-on, which M5Stack sells as a bare board. It matches the Unit PoE-P4 housing, so the two make one block.
Model on Printables Model on Thingiverse
M5Stack sells the Add-on Display In as a bare board. I drew this case for it to match the Unit PoE-P4 housing: same width, same corners.
  • HDMI comes out of one end, the USB-A port out of the other;
  • vent slots on top;
  • one printed part, no screws: four tabs clip into the slots of the Unit PoE-P4 housing. The tabs are thin, so press it on gently.
The Add-on Display Out has the same outline, so the case should fit it too; I have only tried it with the Display In.
  • Ethernet, USB-C and the side ports of the Unit PoE-P4 stay free.
Fits
