← All cases
ESP-KVM is free, open-source firmware that turns an ESP32-P4 board into an IP-KVM: another computer's screen, keyboard and mouse in your browser, from the BIOS up. This is a printed case for one, made by someone who built it. What it does → Try the demo →
ESP-KVM PC case slot bracket
A case by Evgenij Spitsyn
A printed expansion-slot cover that holds the ESP32-P4-ETH and the C790 inside a desktop PC. Ethernet and HDMI come out on the back panel.
Model on Printables
Photo by the author.
For a full-height slot of an ATX case. Three parts, none needs supports: the slot cover, the screw tab and the carrier the boards slide into. The P4 board sits upside down so its RJ45 fits the slot's 18 mm. Bits of 1.75 mm filament work as pins. There is a second carrier for a P4-ETH with the PoE module.
Fits
