0.24.0 - point a phone at the screen to get in
The rescue hotspot exists because the device cannot be reached any other way, which also means nothing can hand you its password. The panel can now: while the hotspot is up, the round LCD gives its whole face to a QR code. Point a phone at it and it joins. Mono OLEDs sit this one out, because a code that small is not something a phone can focus on.
The certificate names the DHCP address. Only a static address was ever put in the certificate, so typing the IP of a device on DHCP landed on an untrusted page. You could click through for the console, but not for the video: a browser refuses a wss:// stream to a mismatched certificate and gives you no way to accept it. The address is recorded when it arrives and named from the next restart.
The button says it heard you. Holding the board button to clear a forgotten password gave you nothing back: no light, no message, no way to tell the button was even wired. The panel fills a ring around its rim as you hold, empties it if you let go too early, and says what it cleared.
Two fixes underneath: the round LCD's framebuffer was not aligned the way the SPI driver wants, so every frame was copied through internal memory - and this chip has about half a megabyte of that, shared with TLS, USB, networking and the video encoder. Turning on a display could take the video down. And when the H.264 encoder cannot get its large contiguous block, the device now says so once, with the actual memory figures, and carries on in MJPEG instead of retrying thirty times a second forever.
