0.48.0 - microSD and WiFi at the same time
0.48.0 is mostly fixes. One of them came from a contributor, and it turned out to cover every board with WiFi, not only the NANO.
On boards with WiFi, the radio is a separate ESP32-C6 chip on an SDIO bus. The microSD card is on SDIO too. Both were set up on the same SDMMC slot, slot 1. So in WiFi mode the card stayed unmounted, and the README said you could have one or the other.
@Crisspii hit this on the NANO and sent a fix in #46. While reviewing it I checked the pins on the other boards. On every board with WiFi the card sits on the pins of slot 0, so the card can simply use slot 0. The two slots share one controller, and the driver handles that.
So the card now takes slot 0 when it is wired to the slot 0 pins, and uses slot 1 otherwise. On a Function EV board in WiFi mode the log shows the card mounted and the C6 coming up on the same controller a moment later.
Video after the target's screen sleeps
A P4-ETH lost its picture for good after the target's screen went to sleep and woke up again. The log said CSI: no mem for backup buffer.
Each time capture restarts, the camera driver frees its spare 6 MB frame buffer and asks for it again. After some hours PSRAM is in pieces, and the largest free block was 2.3 MB. The request failed and capture stayed off until a reboot. The spare buffer is now one more slot in the frame ring, allocated once at boot. I forced twelve capture restarts under an H.264 viewer to check, and the stream did not stop.
H.264 after boot
A board that booted on MJPEG could not switch to H.264 a minute later. The encoder needs one 135 KB block of internal RAM at 1080p. The block is there at boot, but browser TLS sessions soon cut it into smaller pieces. The encoder is now built at 1.8 seconds, before the network starts, and kept whichever codec runs.
On pre-3.0 chips the same failure also never reached the capture loop. So nothing fell back to MJPEG, and the build was retried ten times a second. That is fixed too.
- Settings > Security shows who is signed in and has a Sign out button.
- After a watchdog or a panic, the boot line says how far the previous run got.
