0.56.2 - Wi-Fi that holds a stream
The report
#63 came from the first person to run ESP-KVM on a DFRobot FireBeetle 2. Capture and USB worked. Wi-Fi did not hold: under a 1080p stream the log filled with mempool OOM, TLS write errors and dropped WebSocket frames.
0.56.1 fixed one part: that board has no pull-ups on the SDIO lines to its ESP32-C6, so the firmware now turns on the chip's own. The stall stayed.
Finding it on my own board
My Function EV has a C6 too. I read its flash over the programming header, and it turned out to hold the same esp-hosted image as the FireBeetle's, byte for byte. So I could reproduce the report at home.
A firmware build that logged internal RAM once a second showed it. Before the HDMI cable was even in, loading the console took internal RAM from 85 KB to 1 KB, and the TLS server stopped opening connections. Two things were holding it:
- esp-hosted took a buffer for every packet to the C6 from internal RAM. Its own "prefer PSRAM" setting did not reach that allocator.
- lwIP kept every sent TCP segment in internal RAM until the browser acked it.
Over Ethernet the acks come back almost at once, so neither piles up. Over Wi-Fi they come later, and a page load with several connections is enough.
Both now go to PSRAM. The lowest point in the same test is about 50 KB. Every board with a Wi-Fi chip gets this, in Wi-Fi mode and on the setup hotspot.
I also turned off Wi-Fi power saving. By default the C6 woke its radio every third beacon, about 300 ms.
The numbers from the FireBeetle
The reporter flashed 0.56.2 and counted the same session:
| Over one session | 0.55.1 | 0.56.2 |
mempool OOM | 156 | 0 |
| TLS write errors | 60 | 0 |
| failed WebSocket sends | 50 | 2 |
The picture now runs without a break, at about 9 fps of 1080p MJPEG over Wi-Fi. So the FireBeetle 2 moves to the boards that have run on real hardware.
Updating the C6 itself
I also tried the other obvious fix: putting a newer esp-hosted into the C6 from the P4, over the same SDIO link. That works. The 2024 image accepts it, and its old bootloader starts the new one. But esp-hosted 3.0.9's faster SDIO mode then stalled under video, while the factory image ran clean once the RAM was fixed. So that code is in the firmware, switched off, until I know why.
