0.91.0 - An RK628 driver for HDMI adapters
hardwareconsole
Someone asked in Discussions for the Rockchip RK628 bridge to be supported. It sits on the Waveshare HDMI to CSI Adapter (B), on Radxa's 4K HDMI IN adapter and on the open-hardware WarpKVM boards. This release has a driver for it. I have none of these boards, so it has never run on one, and it may not work.
Why write it without the board
The C790 does the job for me. But some people already have an RK628 adapter, or find one easier to get than a C790. A driver that has not run yet is still a better start for them than none: one log from a real board shows what is wrong.
What it does
  • It finds the chip by itself. Every image carries the driver, and the firmware looks for it after the TC358743 and the LT6911D. Nothing to set.
  • 1080p over two lanes. The chip sends at 1296 Mbit/s on two CSI lanes, which carries 1080p60. A faster source is scaled down to 1080p on the chip. It does not bring 4K: the ESP32-P4 has two lanes, and 4K30 needs four.
  • The same EDID choices as the TC358743, the monitor name included.
  • Sound over I2S, wired to the P4 like the C790's.
  • HDMI-CEC through the chip's own controller, if the board wires the CEC pin to it. Whether these boards do, I do not know.
  • A rev 3.x ESP32-P4 only. The chip sends only YUV422, and the images for rev 1.x boards capture RGB888. On a rev 1.x board the log says so and the picture stays off. Since 0.91.1 a rev 1.x board takes it too, MJPEG only.
It is written from what Rockchip's own Linux driver does. That driver is GPL, so I took the facts from it and no code.
If you have one
Flash 0.91.0, plug the adapter in and send me the log lines tagged rk628, from start-up to a source plugged in, in Discussions or an issue. Whether the picture comes up or not, that log is what gets it to "tested".
The first translation
The console is now in Belarusian too: Settings, UI, Language.
It is also the first language to arrive without a firmware release. A translation now reaches fw.espkvm.io as soon as it is merged, so the next one will not wait for a new version. To translate the console into your language, see the translations page, and open an issue first so two people do not take the same language.
The release: v.0.91.0.
