A slot bracket to put ESP-KVM inside the PC
hardware
ESP-KVM can now sit inside the PC it controls. I drew a bracket that goes into a free expansion slot, like a network card. It holds a Waveshare ESP32-P4-ETH and a Geekworm C790. Ethernet and HDMI come out on the back panel, and the short HDMI cable from the graphics card stays outside.
The bracket from the back panel side: the Ethernet and HDMI openings, the two boards behind them and the USB cable to the target.
It is three parts: the slot cover, the screw tab and a carrier the boards slide into. Nothing needs supports. The tab slides onto the cover on a dovetail, the carrier sits in two channels, and short bits of 1.75 mm filament pin it all together. No screws apart from the case's own.
The tricky part was the RJ45. A slot is 18.4 mm wide, and the jack with the board under it barely fits. So the P4 board sits upside down on tall rails, and the jack goes through a window in the carrier. The boards slide in from the front, stops at the back hold them, and the middle of the back edge stays free for the USB-C plug and the C790's ribbons. The USB cable to the P4 goes through a slot at the edge of the cover, so no plug has to pass through.
From the other side: the P4 board upside down, its RJ45 in the carrier's window, the C790's ribbon looping over to it.
There is a second carrier for a P4-ETH with the PoE module. The bracket is for a full-height slot.
STL files are on Printables, and the bracket is in the catalog with the other cases. The discussion is #105.
