0.49.1 - microSD on every board, and a faster virtual drive
The last post ended on an open question. The microSD card turned out to be slow because the firmware never switched on the regulator that powers the slot's pins, and I had only proved it on the two boards on my desk. Nine more boards have a card slot, and I did not know how they were wired.
They are all wired the same way
I read the schematics. On the NANO, the NANO-WIFI6-DB, the WIFI6, the WIFI6-DEV-KIT, the Module-DEV-KIT, the WIFI6-POE-ETH, the Guition M3-Dev, the FireBeetle 2 and the VIEWE P4-Pi, the slot's pins are fed from the chip's LDO 4 - the same as on the Function EV and the P4-ETH. So they all start at 40 MHz now, and the ones with a rev 1.3 chip can write the card as well.
I have not run this on any of those nine. A schematic is not a measurement. But the risk is small: when a card cannot keep up, the device steps the clock down by itself, to 20, 10, 4 and 2 MHz, and the Media panel shows where it settled. Before this, they all sat at 4 MHz whether they needed to or not.
The M5Stack Unit PoE-P4 is left alone. It has no card slot.
The target reads the drive faster
USB asks for 4 KB at a time. Sending a fresh command to the card for every 4 KB cost more than moving the data did. So when a read follows on from the last one, the device now takes 256 KB off the card at once and answers the next requests out of that.
| Before | After | |
| Whole card, read by the target | 5.6 MB/s | 9 MB/s |
| An image file, read by the target | 5.7 MB/s | 7.5 MB/s |
The same on the Function EV and the P4-ETH. Writes drop the buffer, so the target never reads a block it has just overwritten.
Swapping the image reaches the target
Choosing another image, or handing over the whole card, did nothing visible until the USB cable was pulled and put back: the target went on reading the old disk at the old size. SCSI has a way to say the medium changed, and the device never sent it. It does now, and the target picks up the new size and partitions in a couple of seconds.
Sign out, where you can find it
It was in Settings, under Security. It is now on the rail on the left, under the gear, and it asks first.
